Mk3 1043 SPi bits
Hey,
I'm GT'ing my CL so have ripped out all of the SPi parts.
- A good engine, 1043cc, with a 4 speed box, done 88k, ran sweet as a nut, removed yesterday. Anyone interested?
- 4 13x4.5" steelies with 145/80R13 tyres, all with 4mm tread - interest?
- SPi inlet manifold with injection unit - interest?
- Suspension struts, 2 pairs of - interest?
- Other random bits, please ask.....
If no-ones bothered then it'll all be going to the tip, which seems a bit of a shame to be honest!
  • Replies 13
  • Views 874
will you be going to spring fest?
No 'fraid not, the car is still in pieces!!
hi do tou have the near side bottom arm? if so how much
Yes I have a N/S track control arm. Fairly heavy so £15 posted and its yours...
hi i will talk 2 the guy hu is after the part and see what he is doing with the car I've got to have a look at the car before we start work quite a bad accident he had thanx and will bear u in mind
where abouts in derbyshire are you mate?
if your breaking the engine mate let me know..
ta
mike
I'm in between Ripley and Belper (about 10 miles from Matlock).
Mike - I am breaking the engine - what do you need?
Cool mate I am after the water supply pipe, The metal one that goes into the block just below the inlet manifold, it needs to be the push on type. I've just done an engine swap and have a bolt on one and it ain't no good for the engine I got...
here's a picture of the one i have, so it's exactly the same apart from where the 2 bolt flange is it's just a push fit..
could be interested in the injection kit, any idea if it's a straight(ish) swap onto a mk2 1.3? not sure if the inlet manifold would be affected by the difference in engine size. How much would you want for it and I'm heading notts on may 10th so could collect then
have you got an alternator tension bracket? its the lower of the two brackets
Have you got a 5 speed gear linkage??
Hey,
Hi
I need steering column for genesis
regards
bernie
