So, i took my bumper off to fit spotlights....
I kinda noticed there was a slight bump in the bit below the grill/headlights as it was pushed in a but, thought it would be nothing until i took the bumper off.
My question is, is it going to have caused problems?
It got through a MOT with it so I'm guessing not but just thought id ask on here to be sure.
Whats the best way to pull the body part out? (bit under the grill)
that'll be fine if you wanna fix it just replace it, it should bolt off ;)
Bumper cross member is bolted on, get one from the scrappy for peanuts sorted.
The strip below the headlights/grille isnt so easy. You could get it bent back and lined up roughly, if you want a new one its welded onto the headlight surrounds and then to the inner wing. No so easy a replacement.
Cheers guys
Might just hammerite the rusty bit and whack the bumper on
As for the blue strip, I'm going to pull it out a bit more if i can and spray it black. then it will match the bumper and wont be so obv that its bent. will look a little different too.
