towin help mk3 with no engine
hi is it possible some how to tow my mk3 to a garage with no engine and box in? has anyone done this, i cant take the drive shafts off cause then their aint nothing holdin the hubs in and i cant leave the drive shafts on cause they will fly about all over when the car is movin. any sugestions
  • Views 1.2k
Knock the CV joints off the ends of the shafts and just bolt them in.
Clamp the driveshaft in a vice, get a soft faced mallet, pull the boot back and give it a good smack from behind.
why can't you take the driveshafts off? its not like they're connected to the box anymore....
because the wheel bearings will fall apart. just do what Adam said.
ok cheers mate i was hopin you would reply
aren't they held in with a circlip?
