Drooping sun vizors
I would have thought there would be several posts on this, but my searches returned nothing. Does anyone know how you fix the common (I've had 3 mk.2 that have all done it) problem of the sun vizors dropping down as you drive along?
The only thing I've noticed in my current car is that the plastic securing clips are cracked around the screwhole. Would replacing these do the trick?
  • Views 1.3k
I swaped mine 4 volvo 440 ones they need the edge trimming to fold all the way forward but are much bigger and go much further across the screen, when i took the standard ones off they fell apart!
Just tighten the screw up near the hinge on the visor
That'll be the hinge-resistance adjustment screw. My passenger side one has gone wobbly at the anchorage point. Both screws are tight,but the arm itself moves,preventing the visor from staying all the way up. I dont know what I'm going to do about that. Probably try and find another the same colour (dark grey),which could take a while.
Thanks for the replies, I'll take a look and see if anything works.
(Apologies for triple post... had a connection problem)
This seems to have done the job. Cheers.
