Removing rear bumper
Need to remove the lower metal valance on my 8v bumper, anyone know how to get it off?
cheers
Edited by mk4po-low
  • Views 976
i thin you will need to remove the upper with them allen thinsg u see int he boot and arch liner screws then pull taht off and the lower section youw ill probably see screws for when you have removed the upper.
^^^yup 4 torx screws holding top section on alog with a load in each arch , metal section is held on with 12 mm? nuts <( not definite on nut size, its been a while,) and some more screws in the arch lining, hope this helps :D
oh and two under the bumper near the arches !!
