leak in boot
giving the car a clean today and found that the carpet in the boot is very wet, on the passenger side. have had a good look but cant see where its coming from. and ideas?
  • Replies 9
  • Views 1.7k
i had the same problem in my mk4 traced it to the rear passenger side light, it wasn't sealed properly, might be the same place on your mk3?
yeh its in that kinda area will have look tomo, cheers for the suggestion.
Probably not this but my boot lock seal was shot and was leaking water in. It didn't cause wetness on the floor, but steamed the rear screen up excessively!
i dont think its this to be honest, everything is completely dry apart from one corner of the carpet.
Mine leaked water in one corner when i bumped the back of my car, the back of the car was slightly dented further than the tailgate so all the water that ran down just went straight into the boot, so maybe check all everything lines up and all the seals are there?
rip out the carpet inside etc, the get in it and get someone so run a hose over the roof, try and pin point where its coming in. not to many places it can com in the rear so you should find it.
if it is a rear light wip it out cleen the seal and mating face on the car then smear the seal with vasaline helps give a gd seal
luke
My Coupe-S is letting a little amount in the boot,though only just enough to form a little puddle on the loading sill - the carpet remains dry. The culprit? Licence plate screw holes. I temporarily fixed the plate back on with pads,after respraying the tailgate,without sticking tape over the mounting holes first :retard:
cheers for all the ideas guys, will get the hose out tommorow and try to find it, gotta feeling it could well be a rear light seal, or i hope it is coz god knows where else its coming from.
