Is there more then one shade of.........
Is there more then one shade of dragon green? If yes please state what thay are.
  • Replies 13
  • Views 1.7k
yes there are, but i don't know the names of the different shades
Thanks for the quick reply but it dosent answer my question 100%. (please dont take no offence)
you can get a pearlescent version and a metalic, thats about all i know. there used to be a paint code guide on here somewhere. manufacturers do tend to vary the shades year to year.
When buying new,the customer can bend shades,have been able to for years. When i was a sprayer for a coachbuilders,i never went by paint codes - always matched paint using the cards.
'Brilliant Green' was dragon green.
Thanks i need to find out what paint my car has but the stickers nowhere in the boot atall
have you got the service book? sometimes theres a copy in the front of that
there is different shades of every colour some more than others they will have the same code its a case of going to paint supplies or bodyshop and get them to match with colour chips it also depends on the paint manufacturer
there will be a standard shade then ie lighter,darker,yellow,blue its all down to time to check the colour chips in different lights/positions and spraying test cards.I've found 9 out of 10 times if your blending a panel standard shade is fine
paint code guides only generally give you the code and test pic of the standard shade but a paint supplies or bodyshop will tell you how many shades there are and show you the chips so you can match against your car
luke
When I've done paint in the past I always take the vehicle down to my local motor factors when the light is good. The paint guy there who really knows his stuff, has a book of cards and physically checks the shade against all the others. My paints always been spot on from him.
my local bodyshop have a scanner type machine...
they clean a section of paintwork.. hold this machine against the panel and it comes up with a paint spec...
^^^ those things are awesome had nothing but problems with matching the mars red on my mates mk2 golf the rep from ppg came out with one and it tells what the colour is mental seeing as chrysler prowler red was the match
luke
Thanks lads ill take a fearther look into this
