Wiring in MK5 rears?
Can someone tell me how to do it, and i think this should be a sticky as so many people are getting them..
cheers
Edited by Steevmk3
  • Replies 11
  • Views 1.7k
i asked the same q on another post lol!!
i thought they were a straight swap - i wanna get some but wanna see if they're diff to do b4 i do them.
this might help clicky!
would do this but sounds like a shite load of work...
drilling the hole is the easy bit i think.
its not tha much work, takes 30min
probably less, cutting two wires on one side, and connecting them, and then the same on the other. eaaaaaasy.
Is there any way to do this so that MKV lights on the MKIV will actually pass the MOT?
My reading of the DIY guide suggests that either you end up with your fog on LHS or a red reverse on the LHS..?
Hoping someone can tell me that this isn't the case, as one of my original rear lights is badly cracked and my MOT's coming up. I'd rather not have to replace it with a MKIV light to pass the MOT and then get some MKVs on.
the lights he's fitting in that guide are LHD, if you fit normal RHD lights you'll be fine for MOT
hope this helps :D
Ah, gotcha! Was prob a bit of a dizzy question but I wasn't exactly sure what the story was.
Thanks a mill for that, really appreciate it :thumbsup:
just spotted you're from Éire! mine just passed nct with them on, whereabouts are u?
Livin in Portarlington, haven't got notice of my NCT yet but it's to be in the next couple of weeks.
Now all I have to do is actually get myself some MK5 lights!! Rang around a load of scrappies last week and no-one had them. Where'd u get urs from if you don't mind me asking..?
i got mine from dempseys dismantlers,(096 45412) near ballina, co. mayo, €30 each WITH bulbholders!:D they gave me a discount on them cos i spent nearly €200 between the mk5 rears, a new splitter, passenger side wing, and a few other bits, i think they deliver too. :D
