Plastic and primer?
I'm debating weather to colour code a grill Just wondering if i could sand the grill down with a fine wet and dry and then use normal car primer not plastic primer or will this eventully flake off?
  • Views 1.2k
Use an acrylic based primer and it should be fine as long as the plastic doesn't get flexed a lot.
why not use the plastic primer...saves doing it again
plastic promer promots adehisiveness. i only use it for large plastic bits
Thanks for the reply's.
I ended up standing the grill down and give it a coat in normal primer.
