Replacment bleed nipples for caliper
Trying to get my brakes bled in time for MOT. The rear's are fine as fairly new cylinders but the bleed nipple on the front caliper's have basically 2 setting's - Shut tight and loose !!!!!. I've been using a one man kit which is proberly the problem as when the brake pedal is released the air is getting sucked back into the system through the loose bleed screw thread.
Will proberly just call in a mate to help but I wouldnt mind replacing these if they are only like 50p or summit.
Cheers for any advice
* Just been on www.brake-pipe.co.uk and they do bleed nipple's for 80p but they dont specify the manufacturer or car just the size. Also GSF only do caliper nipples for MK2's
  • Views 1.3k
from VW when i got a price for 6n2 gti calipers, the nipples wer £4 each with staff discount?
Cheers - might just get an eezibleed from Halfords , guarenteed no air will get back into the system and it seems if used properly these things are brilliant.
