Water resting on door sill
Any advice welcome!
water appears to be resting on the passenger door sill, entering the car when it rains heavily. I've checked the seals and all seem ok. The problem seems to be worse under the door mirror as this is where the majority of the water collects, it appears not all the water is being directed through the drains in the door with some draining through the panel.
I had considered putting mastic along the window seal as an additional defence, not sure if this would look messy or even work. However, could it be an issue behind the door panel? If so any advice on how to remove it to have a look?
Thanks!
  • Views 996
Park the other way around. Or on flat ground.
take your door card off , if the foam moulding thing behind the door card is ripped or isn't sealed right it will leak right into the car .
