Mk3 Sill trims
Does anyone know if they're 'side-specific'??
By that I mean is one for the offside and one for nearside? Not sure if it matters what sides I put them on?
  • Replies 10
  • Views 2.1k
Yes it matters,they're different. The nearside is straight at the rear of the car,but the offside has a notch moulded-in for the petrol filler pipe. And with them on the correct way around,the arrows for the jacking points,and notches for the sill vents/water drains,aswell as holes for the rivets,will all also line up.
They bpth look exactly the same to me dude.. cant see the notch for the filler pipe?
Also my problem being that I have a load of schultz along the bottom of my car so I can really see where the holes might be :(
Well at the front end,the jacking-point arrow is is closer to the end than at the back. Place them back to back,as they'd be on the car,and ensure this is the case. The spot-welded flange of the metal sill has raised sections along it,and the trims should have these to suit - ensuring they only fit properly on their correct side.
I've had another look and i gotta say there's no distinguishing marks on the outside faces of them (arrows etc) but I did notice on the backs of them there is a rather cunning 'R' on one and a 'L' on the other :lol: .... but do they mean 'R' and 'L' from behind (so drivers side is 'R') or 'R' and 'L' front the front (so drivers side is 'L') ???
mikey your talking about sills, aron is talking about sill TRIMS
Can you see the part numbers on the sills? If you can compare them to what's on VAGCat and you should get your answer!
No Giorgio,I'm talking about what Aron is asking about - the black plastic mouldings that rivet onto the sills,and thus are the same shape as the sills (apart from the protrusion along the top edge).
the sill trims from what i recall, have the holes for the pop rivets on them, but what differs one from the other, is the pop rivet spacing from the start
the front of the sill trim is the one with the pop rivet FURTHEST away from the end of the sill
so that should be enough to locate them as best as you can
Ahhh there's my answer there
Thank you mate!
