1.0L mk4 polo
selling a 1.0L mk4 polo.. tax and mot. good runner.. spares or repair.. needs clutch pedal welding as I've been told..nothing major wrong with it..needs new door and rear bumper as you can see in the pictures..mileage is 41k...may p/x for a mk2 breadvan, mk2 or mk3 polo saloon.
cheers
gav
Edited by gav6n
  • Replies 12
  • Views 922
does it drive ? any tax and test ?
got pics of the pedal and the problem with it ?
its got tax til end of this month and mot til end of october...it don't drive at the minuite because of the clutch..its the block that the clutch pedal goes onto which as broke. hopefully getting the clutch problem fixed over the weekend.
cheers
cheers
could you tell me if you are getting it welded or replaced? and the cost I've the same problem? i would have drilled and bolted mine but you cant get a drill in there? if you are replacing it it will need all the pedal box
welding it back on.. its a little block which stops the whole clutch cable from moving.
cheers
will you break it if nobody buys it?
i don't really want to break it because i can't be botherd wiv the hassle and haven't got that much room bt i will if it comes to that.
cheers
Hi is this still for sale?
pedal box problem fixed
How much???
Ollie
ye still for sale..
the pedal problem aint fixed.. haven't had any time to have a look at it..
I've got to find out how to get the pedal box off first then i can sort it.
the lowest i will take is 450
cheers
ye still for sale..
cheers
Fix the pedal box and I would take it
Pm me if this is possible. I'm local to you, living in Birmingham
Ollie
hopefully tryin 2 fix the pedal box the weekend..
cheers
car is on flea bay... needs 2 get gone asap
cheers
sold.. :-D
