Roof paintwork troubles
The roof of my mk3 is looking desperately miserable, got a few large patches of lacquer peel, the rest of the cars paintwork is pretty much fine, just the roof that is annoying me, what are my options? how much would a respray be just for the roof? or is there anything i could do myself to it
  • Replies 8
  • Views 1.4k
black vinyl ;) just get some of that cut it to size and flat it on easier cheaper than painting it
someone suggested that actually, will i need to sand down the roof first and would i need to have it applied professionally or is it something i could do myself? is it easy to bugger up i mean
Edited by vwpolofox
i'm in the same kind of boat. Got a couple of marks on the roof where it looks as though birdshit hasn't been cleaned off and its eaten through the lacquer and paint, leaving a nasty mark. rather keep the paintwork all together and not hide any with vinyl etc
I think it would be quite hard to do on a mk3 cause theres no real line for the roof to finish and the pillars to start. My mate did it on his Lupo but the roof lines are very easily set and a bit of trim goes into the roof gutter so it kind of holds the vinyl in place. I think on a mk3 you'd find it would peel after a while if not applied correctly.
yeah you're right about the pillars, would the roof cost a lot to respray? i know it depends how good a job you want, but for a half decent job it couldn't be that much, would it?
just mat black the roof then :)
I satin blacked mine for the grand cost of £2.50.
Looks reasonable as well.
If you want a good job on the roof I'd imagine it would cost around £60-70? I mean they won't have to blend it in much at the sides cause of the black trims or front windscreen. Only real bit is the tailgate, c pillars and a pillars.
Guess it depends if its a sunroof or non-sunroof model to!
It will be a bit of a balache to fade the paintwork in to the origional to be honest .
