HELP NEEDED PLEASE!
need sum info on if i can put polo 6n2 roof drain trims(rubber seals) on a polo 6n
the 6n ones are rupper and the 6n2 are paintable i beleive
let us know if anyone of you knw if its possible and I'm slightly stoned right nw so sory if i dragged on
harv
  • Replies 9
  • Views 1.8k
harv
Lol theres a guide on uk-polos.net, you need a 6n2 windscreen aswell to fit them properly
ash has got a mk5 windscreen and gutter strips hasnt he? pm him
Can i ask what you mean by you need a mk5 screen to fit the gutter trims why's this?
becasue the mk4 windscreen's top corners are rounded off which cannot be seen witht he rubber strips on.
when u put the mk 5 strips on they dnt go dwon over the windscreen so u can see the corners of the windscreen and looks bit dodgy.
square hole round peg sort of thing lol
yup ash has it on his, can make the 5 door strips off the mk5 fit with the mk4 screen with some trimming i believe
MK5 DOOR STRIPS! they re ridged arent they!?? hmm confused :lol:
the roof length is the same on a 3 and 5 door aint it?
Harv the trims fit just fine, best bet is to make someting up to cover up the top corners of the mk4 windscreen which is left uncovered....or just have a mk5 screen fitted...not that pricey from what i remember Ash telling me (although his pricey and my pricey will always be different :lol: )
Thanks for the reply's i might get a pair and try to trim them instead of having to shed out on a Mk5 screen and fitting.
i say what tej reccomended either chip your window BADLY and get it replaced or make some small sections up to fill the holes left by the mk4 strips
