Spraying The Inside Of A VW Badge..What Do I Need?
I wanna spray the inside of my VW badge, but i cant figure out how to seal it all, iv sanded it down and primered it, then I'm gunna spray it but what do i use to seal it, plastic laquer or a plastic sealant?
Any ideas?
  • Views 1.2k
to seel in the gooness? just lacquer.. and push the badge back on and i put a blub of superglue on the back of the pins in the back piece to stop the front coming off again without a fight.
so dude all i need is plastic laquer cos my bro was chattin sum crap about plastic sealing etc..
not as far as i know! when i did mine i... etched it quickly, cleaned with paint brush cleaner waited til dry plastic primered a couple of coats, paint a couple of coats, lacquer a coule of coats... sorted front back on and bobs your uncle.
Depends what you want to paint mate ... Etch plastic primer after sanding it back ..
Then get you you paint on . .
Lots of thin coates no rushing ..
I know you wannrt to get it done but it takes time ..
FFBM
Stevie
I just used normal grey body primer then used a Hammerite metal can, smooth black. Meant to be put straight on to rust but owell, looks good anyway.
Simon
