help ,looking into improving a 1983 coupe
was thinking of fitting double lights fat tyres and maybe lowing. what wheels would look best?
  • Replies 12
  • Views 1.9k
Its one of the very first ever coupes. Ruin it,and you wont be popular. What would i do to it? Maintenance - get it back looking like the day it was registered.
what would you like to do to it? after all its your car and you have to drive it.
if it was me tho i'd drive it in to a wall, leave it out in the rain for a while then slam it on chopped springs and a set of wellers...
Edited by modest mouse
Or rivet on some corrado arches,nice and high up the body,and that'll allow you to get 18s on there.
It's your car, do what you want so long as it's safe. Have a look through the photo gallery sections on here and you'll probably find a bit of inspriation.
All I did with mine was add a few late spec bits. Spot lamp grill makes seeing in the dark loads easier and VW alloys to freshen it up, otherwise, it's generally scruffy, but I love it.
If you've got something more adventurous in mind, go for it.
Could say the same about fitting a 1.6 on bike carbs? Totally ruined the car's originiality for me. Don't know how you could do such a thing.
that was the other option asked friends and got a mixed response some said go for it others said get it back to the day it was registered. glad i asked on the forum. i think hes great as he is so i will just maintain. any ideas on where to get a manual. and info to keep him original so i can make sure i don't ruin it.
You could maybe do somethings to sharpen it up with out changing the look.
Such replacing the rubber bushes with poly bushes. Superflex are good.
Stiffer (thicker) anti-roll bar, and stiffer springs (same ride hight)?
Or maybe thats taking things too far away from standard.
I'd also say get the ignition timing checked, and the CO% to make sure the fuel mixture ratio is correct.
Also check all the vacuum lines and diaphragms on the carb and dizzy to make sure its all working correctly.
Edited by varnish
Good point Yeti,glad you mention it. Inside and out,its as it left the showroom. It has the original dealer plates and Panasonic auto-reverse cassette deck in the dash. Its nerdishly original in every sense but for the engine. And that was built for economy. I made no pretence that id built it to drink less fuel,by using a torquey engine and cutting the revs down. The 1.3 could never hit 50mpg.
if its a low milage tidy example id say keep it as standard as poss! get soem pics up of it please!
I also reported that this near ruined the car. So quick when opened up,i was likely to get into trouble. And its strength before was in being able to really 'drive' it at every-mile legal speeds. It is no longer a 1.6,but the carbs are staying - because they're more efficient than the alternatives. We know of other modded S's,dont we? Does that apply to them aswell,then?
milage not bad for its age its been a run about. will get pics of inside and out on soon.
Edited by 1983 coupe
thanks for exellent advice, we think there is some wear in carb and related areas. we intend to have all his electrical side looked at as well. idea of keeping the ride height same, appeals
I would look into gewtting a webber twin choke DTML they make a huge diffrence to the pokeyness of the car ! I would also look into getting some GLadder Polybushes makes the car alot more direct ..
Personally i think a 40mm drop dosnt take it too far away from OEM but it helps loads with the handling of a coupe's
Polybushes would be my first thing on the shopping list ..
Getting some for my mk2 loon asap
Stevie
