PSD eaton kit
Basically everything you need for an eaton conversion, from the air filter up to the throttle body, including the toothed belt/pulleys, huge awt intercooler, awt metal cooler to throttle body pipe and the matched psd cam
Parts included are:
air filter
induction pipe
5th generation eaton on the psd mounting hardware
modified outlet
modified awt intercooler
awt 'cooler to throttle body hard pipe
silicone pipes to join it all together
ally rad lowering bar
psd cam
my old chip
May split if need be
Anymore info then please call me on 07971 66 66 34
Located in guildford surrey
After chatting with a select few polo-heads, i'm after £1k for this little lot, that is 58% of what it originally cost!!!
Gregg
Pre-modified intercooler
Edited by LregG
  • Views 690
PM'd
BuMp
hi is the charger on the standard size pully? I'm asking this cause I'm interested in the ecu chip as i have an eaton kit but my pully is 19 percent smaller and I'm still running it on the saftey map at the mo. let me know
steven
id imagine so as they're toothed belts
SOLD PENDING PAYMENT
