Cymro's Mk3
I fucking love olives :lol:
  • Replies 141
  • Views 26.9k
  • So the time has come to finally finish stripping the shell 3 years since the crash that killed it. So now its time to rebuild bigger and better, follow up and continue wiith original plans for where
  • harris.racing
    harris.racing
    Great to have you back mate!
  • Decided to get my act together yesterday and restart work on preparing to reshell.....     https://goo.gl/photos/byzBxMfN1kbiJf9Y6   5years standing and I expected to find a r
:lol::lol::lol:
I did the thing of forgetting to get spares, so everything had to be bang on first time :lol:
Rear Axel to Rear cylinder:
I had thought about limiting connections and just going straight to the rear cylinder but due to the risk of a pinch point I decided to use the HEL lines i had lying around.
Photo's @ Volksfest 2012:
Got bummed by the police mate?
Nope, no one told the police about the cruise, so she was threatening to arrest every marshal along the route for breach of the peace, this is the final junction I'm only behind because she wouldnt get out of the way on the dual carrigeway. :lol:
You should of said you'd breach her piece if she didnt move..... :ninja:
Edited by POLOMON
hahaha, you can just see the top of my head in the second picture above the police car. lol
5minutes previous....
Facebook shows it clearer, I've just gone on there for a perv.... 8-)
I love the full braided lines mate look wiked!
Thanks dude, should have some more photos this week.
MOT round the corner and as usual the Polo is in bits......
Head is at the engineering place getting revamped so good chance to sort out everything else I've been putting off.
Shiny Radiator Brace....
Diffrance between the stock and new brace is serious.....(you can physically twist and flex the stock one by hand)
Fitted:
And in the workshop....
All looks too familiar haha, have fun
ye cleaning everything up at the moment.
I'm happy that the first time in 3 years my radiator isnt held in with cable ties. :lol::lol::lol:
Oil filter locoation kit ceri? Not exactly the hardest thing to reach anyway are they? :lol:
I just happened to have mocked it all up. Its also part of the oil cooler setup, only issue is the braided hoses are way too big (kit was for a Focus RS).
And with a turbo in place they are. :lol:
how is is part of the oil cooler setup mate? I'm after some long arse hoses and a setup like that tbh.... :-)
Take off goes to remote filter, thermostatic take off is mounted to the filter which goes to the cooler. all running in parallel.
Block === Filter head with thermostat === Oil Cooler
Even moving the Filter away from the exhaust pipe and into a flow of air will make it act as a small cooler.
Ahh i see i see, so the housing is still doing all the work with take offs and the like, its just in a different place! with you :-)
Ye the take off head screws onto the block, the pipes the go to the remote filter head, where my thermostat plate is also going, then from the stat to the oil cooler.
Normal setup is the oil cooler plate mounts to the block and the filter screws on the end to hold it in place but as i have the relocation head I may as well use it to move the filter away from the exhaust.
Ill take pics of the parts i have.
Nice list from the MOT man....
Both Number plate lights not working - I forgot to check those amateur mistake
Small almost un-noticable leak on front and back off side brake systems - bloody olives
Front offside wheel bearing - again. They don't last long...
Offside ball joint excessive play - another service item...
Both Sub frame front arm joint excessive play - remove, drill out and sleeve the holes
And a new tyre on the nearside front - silly mistake.
Advisory:
Both rear axle bushes deteriorated but no excessive play
Both rear wheel bearings need adjustment
Noisy exhaust....
All in all not a bad or exhaustive list.
whats wrong with teh frame, shit quality rose joints orr are they old and abused?
Nah its the elbow joint the holes have gone slightly oval allowing for play. Tbh the frame has done 30k+ miles of abuse and british roads so I'm not really surprised that parts need renewing.
So going to pull them off, drill the hole bigger and sleeve it, allows for future replacement.
Elbow joint.... that goes onto the lower arm? Pics when your doing it, i may know wtf is going on then :lol:
Lol.
There's the rose joint off the front of the subframe going to the castor adjusted bar, then there's a 180degree elbow that allows a threaded bar to fit through the bush in the rear TCA. Lol.
New 10mm leads from Formula Power:
