Spraying VW Badge - Assistance Please
Sanded It Down Primer, Then Sprayed it but now the paint is running and i cant manage to get it in all the gaps, how do i fix the running without sanding down to primer again, and is there a trick to this?
  • Replies 11
  • Views 2.1k
For a perfect job I would rub it down again..
Why is the paint running, sounds like your spraying too close matey or a lil concentrated in one area! or you have some very runny paint!!! lol
i figured that 2 but I'm not spraying close thats what baffs me..what u recon wet and dry it all then spray it over?
Well you'll have to start again. When spraying,lay the badge face down,on a stand you can walk around,and spray just a light dusting across the badge. Then move round 45 degrees and do it again after,15 mins. Do this until you've worked your way around the badge.
thanx dude, gunna have 2 do that, problem is how am i gunna stand it down in between the gaps of the badge now, gunna take forever!
You dont really need to sand it down between the gaps, just a quick rub in each gap, unless you mean the paint run in the gaps, then i dont know what to suggest, maybe soak it in paint thinners.
Ok, I only just did mine on the front of my 6N the other week. Hopefully this might help you...
  1. Take the wet and dry paper, wet it until the glossyness of the chrome has gone. There will still be the chrome finish however it is in a satin.
  2. Wash away all of the dirt off the badge then leave to dry (I stuck mine on a radiator in a towel)
  3. Now take the primer, spray at least 4 coats (20 minutes minimum for drying) with a light sanding using wet and dry in between coats.
  4. After the last coat of primer, leave for 24 hours for the primer to harden.
  5. Now the primer is solid, take your coloured spray can and spray the same amount of spray onto the badge, only this time use very light sanding in between coats, don't want to scrape away all of the new spray!
  6. Leave for another 24 hours for the colouring coat to harden, if you want, add a laquer.
    Don't forget to spray lightly though, you can always add more and like you've found out, it can be a pig of a job if it runs into cracks etc.
To answer your question on the running paint, the only way I can think of to get the decent finish back is to sand it down to the primer. Paint stripper could work, but it's a risk.
To fully remove any paint from the badge soak it for around 24-48 hours in some break fluid.
Yes this methoud works as when i use to make plastic models sometimes i would strip all the paint off to start over again (saved money buying new kits all the time)
thats overkill on a badge really.
I'd probably go over it with 400grit dry, and then wet.
a good coat of some high build primer (mostly cuz thats what i use day to day) concentrating on getting in the gaps before you paint the face of the badge.
depending how the finish of that is, i'd either give it an hour or so to get hard enough to flat back with maybe some 600 or 800, or i'd give it about 15mins for it to go tacky and apply a coat of colour.
again pending how that coat of colour comes out, it may need another coat, or it may need flatting back with 800 and going over again.
i would seriously not take two days to paint a badge. applying colour onto a tacky primer often helps reduce runs and give a harder wearing finish.
With regards to the runs, soak the badge in thinners, or soak a rag in thinners and wipe the paint off. then rinse it ALL off and allow to fully dry before having another go.
You can use Nitromors automotive paint remover safely on most plastics. I used it on my plastic bumpers. Its not the bubbling acid many people think it is.
Aite guys ill have to give it a go ill let you all know when its done..
thanks for the help..
you done it yet mate :lol: I'm intrigued to know how it went :lol:
