can sumone help me with mirrors please
i have a set of dtm mirrors off me mate and I'm not sure how you change the mirrors can anyone help with pictures ect its a vw polo 6n2 thanks :-D
  • Views 995
If they are electric you will have to take the door card off as well (iirc).
If they aren't, just pull the internal mirror cover off. There should be a big bolt to undo (I think it might be an torx/allen key). Undo that and it should just pull out quite easily.
they are electric miirors I'm having difficulty undoing the screws do you have to take of the door panel ?
the screws are torx so are star shaped go to VW or a local garage and ask to borrow the apropriate torx bit and driver if you can, the card will need to come of as the wiring plug is behind the card. only a 2 sec job if you can find the screws on a mk4 (6n) they arte behind the handle thing. Buy a haynes manual and everything will be explained in there
