could this be where my mystery clonk is coming from
right my mk2 has had a random clonk for some time...sounds around sill height any where between the 2 wheels , kinda like a big bolt rolling about in the door or sill
anyway I've been round it and cant make it clonk by bouncing it or driving over crappy roads etc and cant fault nothing much
I've found the lower door hinge has some slop...anyone think that could cause a clonk while driving? i spose the mk2 body does flex a fair bit
or..give me some idea what the clonk might be
  • Replies 9
  • Views 1.9k
Exhaust clamp on the floorpan?
deffo sounds right over near the sill
seat mounst abit loose or something maybe?
bonnet rattling up n down??
i had a really anoying rattle and it was because one of the foam thingys on side of bonnet had fallen off so it was rattling around on the hinge
doesnt sound high up enough to be the bonnet
does anyone recon that lose door could move about as i drive?...kinda sounds like it when i move it around but I'm not sure it can move much when driven
close the door and see if u can move it about when its shut...
it is the upper hinge...cant believe its taken me so long to find it lol
sorted, did you ever find/cure the leak you had?
the fuel smell? no i haven't sorted that yet, i noticed the filler cap seal is a little perished and need to check the hoses on the filler neck
also i think the filler cap is non vw , so maybe a proper one would seal better?
