G60 carriers & discs
I have got for sale a pair of g60 carriers which have been sandblasted, the slider pins have had 2mm taken of the heads so you can used new pads. Also included 2x280mm discs which have only had 150 miles use.
£50
The carriers have been sandblasted and treated with acid etch primer. The make of the disc are ATE which is o.e.m quality.
Edited by M9OLO
  • Replies 11
  • Views 771
is that everything you need to get them onto a polo except pads?
as well as pads you will obviously need callipers depending what car there going on.
Let me know and i will try and help you.
will u post? and how much?
thanks
carl
pm'd
bump
Hi m8, on the valver can you use the standard calipers with the G60 carriers and shortened pins and 280 mm discs ? Any help would be good thanx, also can you post these to donny ? Thanks
yes you can and yes i would be able to post them.
You have PM, i gona have these bad boys :-D
would they fit staight on to a mk4 polo? and would you post?
Heeeeeeeeeelllllllllllllllllllllllllllllllllllllooooooooooo ?
Ill take them if they are still available? pm me
