Buying Advice
Just after some advice, if you don't mind.
I have found an S reg 1.4 CL 3 door, silver 87k mile, 15" VW alloys with nearly new tyres, new exhaust and brakes, loads of cash spent on it for its last MOT. It was MOT'd over a year ago and has just sat in a garage since. Its got no TAX either.
All this for £800, but, the clutch biting point is really high, the gearbox is making a strange sound that goes away when you dip the clutch and the gear stick is really sloppy and I dont know if its had the cam belt done or not.
Thinking of offering £700 but do you guys have any advice on the clutch and gearbox issues, that would be great.
Phil
Edited by Pamoothican
  • Replies 10
  • Views 1.8k
I'd personally carry on looking around if the gearbox and clutch arn't good. Then cambelt on top. Unless you know how to replace yourself, you're easily looking at another £700 to do all them.
I'm handy with a spanner, I'm not worried about that.
If the clutch is not stiff and its easy to get in gear, if a little soppy, could it not just be the cable that needs adjusting?
But you find me a polo within 30 miles of Newcastle for £800, even if it needs a clutch and a cam belt that's still gonna be less than £1000.
Phil
I paid £750 for my '97 1.4CL, it was on steels, needed service and cambelt. They cost £300 to sort so roughly £1k (bearing in mind, cars cost to maintain so expect the cambelt to be done). Biting point is high, as is with a lot of people's who i've spoken to so seems to be a common problem. Offer him £600, worst he can say is no!
I paid 1000 for my 98' cl, mechanically sound, although the brake discs have seen better days. And there's some patches of rust. but i take pride working with paintwork so i'm not fussed, i'll fix her up and she'll be concours in no time. Prices vary.
well I think I might just go with a cheeky offer.
Bodywork is mint, its covered in dust as its been sat in a garage for over a year, but should scrub op OK.
Just need to investigate the sloppy gearstick.
My 16v has the same gearbox/clutch issue. The strange sound on mine feels like metal scrapping along each other, which goes when the clutches dipped. This leads me to believe the gearbox has gone which is costly on the 16v but should be readily available for a CL. As it needs MOT/TAX and has them issues you could try a cheeky offer of around £600
you pretty much just descriped my car! was advertised at 900 offered 700 dealt at 750. biting point is high, but got it checked and isnt anything to worry about. easy adjustment...
Well had another look at it at the weekend, and basically its fooked, oil in the water and mayonaise in the oil filler cap and down the dip stick.
Just go in with a cheeky bid. The worst he can say is no.
You still rolling around in the green destroyer or you got your GTI back on the road?
Its my lasses mates and she's a right pain, she wants £800 so I told her its fooked and she said so! offered her £250 for it and she told me to shove it, cheeky so and so!
Using my dads 206 at the mo :ninja: , its wank, but does 500 miles on £40 of diesel.
Still got the the green meanie gonna try the old golf suspension and wheels on this weekend, just for shits and giggles.
Only got till the end of the month till I'm done at Uni, then its project fixeroo on the valver.
How's the lupo and the derby?
