How much should i be paying?
How much is an accurate price for a 57k Engine and gearbox out of a GT?
Been in a crash so just getting the shell. NO Front end damage whatsoever.
And how much would it approx cost to do a conversion from a 1.05l?
I would say 100-150 for just the conversion parts. But if you are getting the car as well depending on damage 150-250. Really all the parts you need are there. It might be worth renewing the water pump and cam belt while the engine is out as its a lot eaiser. And perhaps the engine mounts as well.
As for paying for a garage to do it I got quoted £800!!!! Its an easy job and quite straight forward.
Edited by max_crox
I reckon about £200 - 250 for a whole car, depending on the damage on the outside you might get a full set of arch trims, Interior - seats, carpets etc
plus the piece of mind knowing that you really do have ALL the bits for the conversion.
i paid about 200 for a wrote off GT square to gt my polo, that had every thing with it, including all the interior.
and i just did the swap myself, cost about £40 through sorting my mate out for helping me.
the drivers side door is destroyed. The bumpers are fine still got a full arch set. All interior, clocks brand new head unit.
Would i need to buy anything really to do the swap then? Is there a guide anywhere, i had a look and the only guide on heres seems to be from GT to G40. Is it just about the same thing?
everything is plug and play so should be a straight swap
