60mm Drop on a 6N
Just need some advice really.
Me and my mate are going to put in new shocks and springs in a week or so and i would just like to know would 60mm be too low? like will i start bottoming out and stuff.
60mm vs. 40mm what do you reckon?
Cheers in advance
  • Replies 25
  • Views 3.5k
ground clearance youll be fine at 60, but it depends on what size/width/offset your wheels are obviously.
i thought you could lower 6n's by like 110mm and still use em as a daily
is that true?
hope your lowering process works out they way you want mate
I'm running 195/45/15 tyres on TSW Freeze alloys would 60mm be ok?
depends on the offset really mate, you would be better off with coilovers as you can then set the ride height at how you want it??
try 120mm :D
60mm isnt low enough!
Anyone know of some coilovers that are approx £200 that will allow me to go more than 60mm?
If so are the coilovers any good?
Look on here for PhilJ mate..
jackson tunning.. 200 quid and yeah a lot of people on here use them.. You get what u pay for..
And yes some 6n's on here are 120 and used daily.. And foxie on that note.. there are some kick ass bumps over near your GF'splace how the hell do u clear them?
one word, two letters, NO!
here here
dont wast your money with spring kit, just go coilovers
is that true?
I do a good 70 - 80 miles a day with my car all the way down on coilovers. Which should be close to 110mm. Its no problem at all.
When I had my car down just around 60mil though I found it handled better and gave a better ride. So I'd say 60 would be spot on.
I'm just stupid and sacrificed performance for looks :)
60mm is better than 40!!
i got mine down 75 on front and 60 rear on 195-45-15's offset 35mm i use it daily and have no rubbing unless you hit a bump quickly, lol
look into saving up for a set of coilovers......that is one thing i regret not doing, much rather have a choice on height!!
Good luck
Ben
60mm should be ok. Much lower and it's going to rub and make it undriveable. I'd rather have a car with a 1 cm arch gap that handles than one with a -1 cm arch gap that is undriveable
used 2 be 130ish down rode like pooo poo but looked ace ;0
I'm at 60mm I do get the odd rub off the arches on big bumpy roads. any lower for me and she'd easy bottom out on the roads I have to travel. I'm also running 195-45-15 et35 I think wolfrace voodoo2.
so for ride comfort would 40mm be the best? standard right now feels like on stilts...
I rather 60mm to be honest as I like a firm controlled ride
but for passengers 40mm would be better? or am i splitting hairs lol
As I said before my car is down close to 110mm probably (actually while I'm here if some standard height Mk4 owner would like to measure the ride height of their car so i can compare mine that would be brill :thumbsup: ) and I've had a car full of people and still no rubbing or scraping!
ill measure mine tomorrow (from the body to the ground?)
Mine is 60mm all round and its fine with two people. If I have a rear passenger then the rears rub over dumps.
Yeah just any measurement mate.
One front one back preferably aswell :thumbsup:
Just lowered the rear but forgot to take measurements i do have before and after pics tho i will post them tomorrow once the whole car is complete.
Going to head down to eurocarparts and get new bearings :-D
Oh yea and there is somthing a little tense about having a compressed spring between you are legs while you rebuild the strut haha.
Well if you know how much you have dropped by then just measure your car once its settled down after a few days and I should be able to work out mine for that.
Unless some other kind soul wants to measure their standard height Mk4 for me :)
