Seized/rusted bolts
Hi all. Tried taking off the front bumper on a 6N today to find 4 of the bolts are rusted to s**t. Thread has also gone..
What would you recommend to get these off safely without buggering anything else up? I've been looking around and found screw extractor LH drill bits?
I'll also need some replacement bolts, so do you know where I can get them from?
  • Replies 10
  • Views 1.9k
Could you not use a dremil drill like power tool with a cutting disc and cut a straight line on the head of the bolt so you could then use a screw driver to undo the bolts?
Edited by 1stgolf
Not a bad idea at all, if I had a dremil drill :p Only bought my first set of tools today! New to this game and already stuck at the first hurdle! Gonna attack it with a screw extractor tomorrow night, and if that doesn't work I'll try and get hold of a dremil :-s Why do they make such naff screws?
Your guess is as good as mine lol
hmmn you better hope the bolt isnt rusted to the thread it self...
then you may have to drill the whole thing out....
and re thread the hole and get new bolts i suppose...
just suggesting in case it does happen!
if you can get at the thread with a wire wheel, try and clean it up a bit. then spray with wd40 and heat the bolt with a heatgun. works wonders
Hmm had another go tonight. Managed to remove the bumper by hacking away the plastic around the bolts, so thats at least off! Tried the 'screw extractor' - total waste of time, snapped within 30 seconds *inside one of the bolts* and since it is harder than a drill bit that isn't ideal..
Think I'm going to need a dremil after all...
Hmmm that tool is not as good as it looks. Had one and it's identical to the JML one sold in Woolworths. Whilst great for the minor hobbyist who builds models and stuff it does NOT have the torque and quality bits of the Dremel tool.
I guess, as always, you get what you pay for.
Thanks, but the link doesn't seem to work anyway! Really not sure how to get these feckers off.
