rear exhaust brackets on mk3
Has anyone else foun the brackets the back box hangs from to be very flimsy? Recently had to get it on the ramps and weld in some extra strength as the back box kept dropping and nearly falling off. Anyone else had to do this little bodge?
  • Replies 44
  • Views 4.7k
yeah a had to make up a completely new one recently think its fairly common, think lowering and stiffening the car makes it worse, by the time i realised i had a problem tho mine had left the car completely! :lol:
Small speed bump saw mine were usueless i find a massive zip tie helps to keep the exhaust up until you can take a welder to them.
i agree completely, my backbox is held on with metal CV boot wrap and some tie wraps too
nice to see i'm not alone lol
i have some industrial size cable ties helping to support mine at the moment.i've got a brand new hanger section ready to fit once i've reinforced it with some thick plate
haha yes there crap!!
my backbox is held on with some bike chain altered to the correct size, couple o tie raps and one original exhaust rubber :)
i have to admit tho...my hangers have been changed for hook thingys instead of them metal whajimicallits
think i'm going to add the massive zip tie back on just for safety knowing how crap they are lol
yeah just whack one on....not do any harm..
I made one with couple of bolts and a bit of metal I had lying around :lol:
Pikey and looked crap but it did the job. Withstood cup car suspension so must have been strong, lol.
same as my piece of bike chain lol
was adapted to size...as a temporary measure, seems sold as a rock so am not touching it! :lol:
i might just do that you know, how did you clamp the chain? with a padlock? hahaa
I'm being serious tho neil?
hahaha, well i took abit of leftover chain from bikehut at halfords and there park tool chain puller apart'er n putter back together'er
made it the same roughly smaller size than the exhaust rubber and placed it on then stretched the rubber on the other hanger...
some tie raps to make sure it dunt move or come off, jobs a good un :)
mine fell off on a country road! the mount just gradually bent down, so i bent it back up, used a load of gardening wire to reinforce and help take the weight and cable ties reinforcer the rubbers onto the mounts on the car! Abit of a bodge but it works well! Il get it sorted out after the more important things have been fixed!
mine is held on with petes washing line lol
I'm currently getting some brackets made up, taking longer than planned, but they will bolt on and do job, watch this space lol
my 1st was was real bad so i used one of those metal coat hangers you will have I'm sure lying around in a cupboard that worked a treat
we'll have to devise a mod for all mk3's and market it seeing how big the feedback relating to how crap the brackets are lol
I bought mine and the exhaust was held up with electrical wire... it still is until I sort a new engine and zorst...
think just about everyone's had this problem they are no where near as strong even as mk2 ones, my mk3 has standard exhaust and that bent, i braced it across between the hangers with a thick bit of metal and bolted it through the hole that the rubber bung sits in, ideally id put some weld on it to make sure it wont move but it seems ok so far I just keep an eye on it, typically exhausts seem to fall off when my other halfs driving it and he's not such an expert at pikeying things as me :lol:
Ha ha i've added extra welds but its still a bit shit to be honest
will the heat from the backbox melt some THICK THICK tie wraps? proper thick i mean!
thats all thats holding mine on now really...
I drove round for 2 months with nothing but one of them holding my exhaust on and it seemed fine though i did'nt do much motorway driving to get the heat right up
dougs exhaust hangs very low on his mk3 aswell
it makes sparks wen you go over a bump 8-)
someone make something to hold them on properly! and mass produce it!
I've just driven to college and it smells like they're melting... i only put them on last night! maybe i need more of em to be sure!
