gearbox blew again!
4th time?!?!?! i dont know whats going on?! either the people who are fitting these gearboxes are fitting fubar'd ones?! or my car doesnt like gearboxes?!!??!1 ffs!!!! i dont drive like a chav, i take it easy all the time, low and slow lol
argh!!!!
any other people with mk5 polo gti gearbox problems on this bad scale?
  • Replies 21
  • Views 2k
They are fucking shit!
Why anyone would put the time into mk5 gti's i have no idea
Always be known for shit boxes on those Engines
I would go with a lupo GTi box, same engine after all.
are you getting second hand ones or refurd ones??
my mate when thow two in about a month now his engines gone
how low are you mate?
not a straight fit unfortunately, a lot more work involved than it first appears...
Strange cause a Polo box goes straight onto a Lupo.
They share the same casing numbers, so I would have thought they'd be exactly the same fitting wise!
sell mk5 buy a mk3 8-)
Lupo GTI box would cost thousands probably to get it fit the Polo. I think the quality of the gearbox after the first rebuild will depend on the garage doing it
Difference is between the 6 Speed/5 Speed I think? Wouldn't be surprised if the Lupo 5 Speed was just as pap?
speak to a guy called matt on here with a dragon green 6n (the guy who dunce is on about) & I'm sure you two would get along great
he got fed up & now owns a mk1 fiesta haha :lol:
The Lupo box has got differant linkages and the clutch is hydrolic and not cable operated!
if your anywhere near warrington give black diamond a call on 01925 41 66 19. they are a gearbox and axle sepcialist specialising in the overhaul of gearboxes.
I'll keep that in mind incase mine starts whining Stu!
thanks guys!! I'm 60mm low on the front and 55 on the back (ish)
i got a company in docaster called gearbox uk doing it, but I've had...3 from them, so thinking of going somwhere else lol! can't be good really
wasnt there a guy talking about a company that fit after market or different car gearboxes into polo's or somthing on here a while ago?
hhmmmm
i hope it gets sorted soon, I'm driving a corsa 1.0l lol
you sir, need a new car!
IMHO, after the second fail I would have gone elsewhere!!!
Which part of the gearbox is failing?
if its a diff/diff bearing related failiure then, its proberably because you are too low...Causing the driveshafts to put to much load on the diff bearings
Blew mine up 3 times, but i love the car and dont want to sell it.
I've even learned to take it out my self and back in now - so its just my own time really :lol:
dont get another recon box get a remanufactured box (completely stripped and everything replaced) costs more but was what i did when the my 2nd box went
people will not learn though....the constant "tune up my gti" threads
ye would be nice if lupo box went straight in but i think the main problem is the lack of the hydraulic clutch
Chris, I don't think you are too low but its bad that you will have gone through 4 gearboxes now! My GTi is about 50-55mm down and I've done nearly 25,000 miles since lowering the car with no issues. I had the gearbox oil flushed and changed at 77,000 and will do again when I book in for a service at the beginning of May when the car will be reading at about 96,000.
LOL no probs. they are a great company also doing services and other mechanically related stuff.
also do black diamond brakes ;)
