hinge pin removal on a mk2/3
okay I've found my mystery clonk ...its wear at the upper hinge pin
I've swapped on a golf before and it was a complete **** , so I'm looking for any tips on how to change em
  • Views 2.3k
I've removed MK2 doors and dont remember any problems. Of course,doors are absurdly heavy to handle alone,even the MK2's,and a padded-topped jack had to be used. But you're only swapping a pin,so just using a stable jack (trolley,trolley or trolley) to take the weight,and having everything to hand (hammer,greased replacement pin,beer) should make it an easy job.
maybe the golf was an extreme case, but the pin was almost impossible to budge lol
I've had to do this 3 times and twice I just hammered it untill the pin popped out but the last time I did it the pin would not budge. After an hour of umming and arring I ended up getting out ol' faithful (grinder) and just cutting he check strap off.
Was ages ago and haven't put the strap back on so I dunno how hard its going to be to change the check strap tbh :lol:
what you on about cutting the check strap ? you lost me there
I'm on about changing a worn out pin for the upper hinge...if thats what your on about too, did you belt the pin out from above?
buy a proper hinge pin removal tool or you will knacker the hinge or the door, avbailable through eastwood,
whats the proper tool like then? never seen one for this style of pin
right just did the job
it punched out suprisingly easy with a club hammer and stout punch , the new one was hard work to knock in but not a bad job
one tip...the pin has a flat end and slightly pointed end, the flat end has knurls to grip the hinge so that end needs to come out first
