bonnet lifters??
recently put some in mate said they should just bolt in one side did the other i tried drillin in same place but on the otherside so fitted shut the bonnet an ahhh its wonkin the side that bolted in is a few mm above the side wing an the other side is an cm below the wing is it just a case of re drilling the hole to bring that side up?? HELP!!
Edited by 8vpolojack
  • Replies 8
  • Views 1.7k
please some one help otherwise I'm going to have holes in my car from all the drilling?
any one know how to fill these extras holes just incase i have to redrill??
if u have to redrill get some of that putty stuff that u mix in yoru hands and turns into liek steel when it dries, liquid steel or soemthing its called. and what u mean above the wing? the wing goes the lenght of the front? i found it best to fit the upper section on the side to be drilled shut the bonnet as far as you can but stop so you can still get your fingers in and kinda scratch in the paint where the threaded screw goes in.. then drill.... thats all i did when i did mine mate.
epoxy putty i think you're talking about?
used some to fix my electric window regulators haha. mine cost me a fiver from wickes but guessing you can get it from any hardware store
hmm that sounds about right, a silver label and black writing iirc :lol: i got it from halfords iirc.
WELCOME btw too mate
cheers guys might try tht shutin the bonnet an scratchin thing an getting that putty stuff wickes u say ill go have a look 2moz thanks for your help
just had a look at that stuff and its called quiksteel, try halfords or b an q....
cheers fella while u looking at this topic your strut brace did you move you are coolant tank an drill the brace holes what bolts you use?
u mean the header tank or washer bottle? the header tank i relocated on a custom fabbed polished bracket so its more to the front and out.
naa the washer bottle is still there. i used some nuts and bolts i had lieing around to fasten the strut down, they were the perfect size and i used some spring washers and locnuts underneath. abit of paint and copper slip in the hoes so they wont rust and it was reet.
Edited by POLOMON
