Mk 3
About to close the deal on a mk3 cl coupe. been out for a drive with the owner, no knocks. Maybe a wine fron the rear drivers side, apart from that the ride was good.
There was a few small niggles.
One; The rear seat doesnt move forward. Wire came loose? easy to fix??
Two; The passenger side door only opens from the inside. again easy to fix?
Three; There no passenger side wing mirror, on the car now. (does come with one) tried looking for a brakers yards to get one. no luck. I no I will be able to get one
For £200 its a nice 1st run about.
Just want to know if they things can be sorted cheapish. =]
  • Replies 12
  • Views 1.8k
200 quid aint bad if you say it runs as it does...there only small niggles, not like bottom end is about to explode
possible wheel bearing failure
new handle for door
door mirror, i have one floatin around in the shed, there easy to find :)
put another 150ish including the front wheel bearing if it needs duin...
new handle for door
I was thinking bearings. only heard it when he was pulling away
He wants £250, but I'm going to offer £200!
Will keep me busy for a while!
200 quid should be safe, not much to loose!
Probably doesn't need need door handle. Mine was doing this, just needed un-screwing and re-seating then just tighten it back up
like wire came loose. door card off job? I've done it before with my brothers Lupo.
sorry about all the dumb quesions.
no wires init, but yes door card off, 1/2 hour job, just fiddly!
You dont need to take door card off to remove handle, just 2 screws. 5 min job
thats a good point...should know done it ma sen :lol:
Check that the battery tray isn't rusty.
They go here a lot on the mk3's. It can be repaired by welding a plate in or pikey'd with some body sealer. However, if its been leaking for some while the drivers footwell could be wet under the carpet. This can lead to further rust problems here.
Also check the condition of the fuel tank filler neck. These go rusty and a replacement tank is around £60-£70. If your not up to fitting it, a garage will charge at least 3 hours labour.
Any other rust issues are gonna be mainly cosmetic.
Rear wheel bearings are cheap and easy to replace - sounds like the problem you describe. However fronts are neither cheap nor easy!
Check for oil leaks on the front of the engine block/head joint just above the alternator. Also any signs of oil in the expansion bottle or creamy coloured "mayo" on the underside of the oil filler cap. These all signs of a potential head gasket failure. Very common on these cars. Not too expensive at all if you can fix it yourself. Again if you can't and need a garage to do it, I'd pass it on and look for another.
Its really not viable to spend hundreds of pounds on a car that's worth fuck all when there are other better examples to be bought. Its really down to how much work you can do yourself.
Good luck.
Good luck.
Thanks for that. :-D There was a bit of rust on the boot lit. only cosmetic. Also the creamy coloured "mayo" on the underside of the oil filler cap. Wheeler dealer has been worth while. after all :lol:
just hope that mayo's condensation!
whats the mileage? head gaskets tend to go around 80k
