How to get these little b******s out?
Anyone know how to get these out in order to get the entire seat cover off? I've tried levering them against the top of the seat but no luck and it feels as though something's going to break if I put much more pressure on them. Are they a straight pull out or are they secured in there somehow? Is there a knack to it?
  • Views 1.6k
Done these on mk2 seats last week...there's a slide on C clip on each side which you need to lever out with a flat blade screwdriver and maybe a gentle tap from a hammer. To remove the actual plug bit which the headrest slides into they are 4 pronged and a bugger to remove with the fabric on. Get the C clips out and you should be able to lever the fabric over them- depends if you're keeping the fabric or not.
If you slide the fabric up to the top of the seat (so its only still held on by these),can you not then get to those things from the inside?
never worked on that actual seat before...but all the vw ones I've had apart need you to pull the cover up half way then use a socket or similar to push the prongs down and allow it to pull off
they have like a fish hook effect on the bottom...no amount of levering will get it off without pushing in the hooks
Yes. They are very brittle though so I had to cut one of the prongs off to get it to push together and lever out.
A socket up the tube! Sounds like a good wheeze - I'll try it tomorrow. Thanks guys.
Haven't tried again with the Mk2 ones, but for the record, the 6N ones look like this when they're out and I found the best thing to shift them was a sharp flat-blade screwdriver pushed in from below, one side at a time.
