Polo 6n horn (its Pants!)
Hey!
I just wondered if anyone new where the 6n's horn is located, and how easy new ones are to fit. The standard 6n horn is pants!
Also any idea on where to get one from, i only want a louder one, i dont want some airhorn that gives people heart attacks though :D
Cheers!
  • Views 2.3k
If it's the same as on the 6n2 (and I think it is) then it's in front of the front left wheel. I made a blog post about replacing the horn on my 6n2 here, if it's any help.
I have just recently replaced my standard horn with a Stebel Nautilus it was £22 from halfords and comes with a relay they are well worth the money.
All you need to do is wire the relay coil to the existing loom and then wire the switched part of the relay to the positive of the battery and then to the positive horn terminal, then connect the other horn terminal to the negative on the battery.
It would also be advisable to put a fuse on the positive feed, the instructions recomend 20A on 12v and 10A on 24 volts.
The horn is well worth the money and very easy to mount, i am off work all of next week so i will post some pictures of my setup for you.
Kind Regards
