Illegal Spare Wheel??
you dont have a spare wheel when your spare wheel in use on the car. aha
so nah you dont need a spare. ;)
  • Replies 32
  • Views 3.8k
Never once been asked to open the boot to check the spare. but was picked up with my saxo due the cage not being secure as one hinge bracket wasnt fitted properly by myself.
My polo passed without its reversing lights, MOT tester was happy with my rear spots as replacements but did warn me about them being manualy switched in case i left them on.
A certain MOT garage chain in N. W. Wales currently seem to be employing semi-blind testers, that notice small rust holes (1cm) but fail to notice that the exhaust pipe isnt even in one piece and that were the mounting should be is in fact a massive hole.
Edited by Cymro
I used to help out at a garage, and i was told that if there is a light, the bulb must work. we used to test all lights including reversing light, was a bit of a dodgy garage though :lol:
Some testers will check it as a matter of course and either give an advisory or just mention it when the car's picked up.
yeah most garages are ok saying they will pass you as long as you fix it, some will pass you but charge you a bomb for replacing a bloody bulb!!!
i had the same with a wiper that was cracked, they said it would be a fail unless i buy one off them which was about £15!! rip off merchants or what!!
Right.. :)
You are not breaking the law if you don't carry a spare.
You are not breaking the law if you are carrying a spare that is bald or not roadworthy. It is breaking the law to use that wheel though.
You do not need to have a spare wheel for the MOT.
If you have a spare wheel it does not need to be legal for the MOT.
The spare wheel is not tested on the MOT. You might get advised that the wheel is bald or missing but that's it.
Thats not true, if have a spare wheel it does need to be legal for the MOT
Yep I'm a gimp... ignore that false bit of info
I give up.
Spare tyre is not tested during the MOT. If the tester happens to notice a problem with it during the course of the test, he may give an advisory, either formally or informally, but not fail the car.
Reversing light is not tested during MOT. If the tester happens to notice a problem with it during the course of the test, he may give an advisory, either formally or informally, but not fail the car.
That is all. Closing this before anyone except those that postted it believes some of the crap in this thread.
