Newbie question Mk2/Mk3 doors
Hi I'm a total newbie here and not a Polo expert at all
We have a friend who's an oldboy with an M Reg Fox Coupe 1993, looking at the web I think it's a Mk2F (but some seem to call this the Mk3) It's definately the pre 94 model
Getting to the point, he's had a dent on the passenger door, I've said I'd fix it for him
Due to the size of the dent I think the best option is to swap the whole door
I've found an 85/86 Mk2 coupe door (pre-facelift)- will this fit?
Would any other doors fit - ie square back (sorry if this isn't the name)
What's the best way to swap the door, do the hinges unbolt or will I need to punch out the hinge pins?
Finally does anyone else have a door for sale, 93 Fox Coupe passenger door?
Many thanks in advance
Ian
  • Views 1.2k
That's what's commonly called a mk3, though some call it a facelifted mk2.
All doors are the same regardless of bodytype, be it coupe, square, saloon or van.
Mk2 and 3 doors aren't totally the same, but they are interchangable.
His facelift model has side impact bars in the doors. The earlier door doesnt have.
Thanks very much for your answers, that's a great help as it gives me more chance to find a spare
Any advice on how to swap the door?
unbolt the 2x 15mm bolts and knock out the check strap pin
the bolts are fairly tight so have a good socket and decent sized bar
