where can i get the rubber bit between roof and ariel?
the rubber bit the sit on the bottom of the ariel base on my 6n has split and come away.
does anyone know where i can get one other than the main dealer, they only suppy the part with the ariel base which is 71 quid?
  • Views 1.3k
eurcarparts,GSF ???
a scrapper might have one in better nick, or the main stealers direct.
Hello again,
The part number from the dealer is: 1HO 051 753 for the repair kit.
You may be interested in a guide to help you do the procedure. Again, much kudos to the chaps who wrote the DIY guide.
From Uk Polos:
http://www.tigerstyle.co.uk/poloforum/view...e46b0c41af6335a
Kind regards,
PoloD.
VAG parts is where i got mine from
Hello again,
From Uk Polos:
Kind regards,
PoloD.
Exactly what i need thanks :-)
