No Rev counter but want one
Is it possible to fit a rev counter when i dont have 1 already what do i plug it into...i have a 89 mrk 2 squareback
any ideas how to fit or if even possible thanks:D
  • Replies 9
  • Views 2.7k
Whats wrong with having a clock? :lol:
You dunno when to change gear.. LOOOOL
Yep it is mate. very simple to wire up to. live wire to the battery, earth wire to a ground, and the sender wire to the coil. if u get a rev gauge it will come with instructions anyway.
If you buy the MK2 instruments that have a rev counter,from a breakers,it'll plug straight in. You can even swap the speedo's around,so you keep the one that has the correct mileage.
worst part of the job is removing the speedo cable, after that you are laughing.
get coupe s clocks run the speedo cable to the gearbox and your sorted really trust me i have put them in my 90 loon but try and get some with a similar milage its so irritating when they wrong specially if its higher like mine are 10k ahead of themselves so it goes on mot cert :-(
Not that hard to swap the speedo over!
carefully peel back the blue stuff, undo 6 screws. voila
WICKED!!
thanks everyone i am gettin new clocks outta another polo...will come back if I'm stuck lol
