1.4 6n injection rail, ECUs, inlet manifold
areet guys and gals, I've got a 1.4 throttle body off a 6n polo for sale, also the plastic inlet manifold, injection rail, and a few other bits I've now forgotten because i was to lazy to write it down when i was at my garage thinking my memory was better than it is. not sure how much its all worth so if anyone makes me a reasonable offer. or better still if anyone has a GT cam from a 3F they want to swap that would be greatness
matt
Edited by oldrope
  • Views 391
matt
Is this in 100% working order?
Where are you based?
as far as I'm aware, was removed with the engine due to G40 conversion, i scooped up the engine for my rebuild and carbs so its not needed by me. in near cardiff
bump, throttle body sld to the good man above.
rest still available, injection rail, inlet manifold, couple of ECUs
