facet fuel pump
Facet Solid State Fuel Pump - Road so perfect for bike carbs or just to replace a mechanical fuel pump.
its been used for about 100miles and has the extra ends which u have to buy seperately. easy to install i just boted to bulkhead and tran it on a switch or u can run in off the coil so it turns on with ignintion, simple as.
pump was £35 and ends £8 plus postage.
I want £30 posted
  • Views 465
bump
you got the part number for this matey so i can find out the flow rate cheers
u still got this? please pm me if thats ok cheers
Pressure (Psi): 2.5 - 3.0
Rate (Gals/hr): 12
thats the flow rate, still for sale, pm'd
