6n gti bumper?
hey folks
i am having trouble distinguishing between the 8v, 16v and gti bumpers on the 6n.
(or do the gti and 16v imply the same thing?)
  • Views 1.2k
From what I can gather, the 16v bumpers are the same as the german GTi bumpers.
The 16v/GTi bumpers are one piece, with a large centre grill and 2 smaller ones either side. The 8v ones are 2 piece, an upper plastic piece and a lower valace. The lower section held a single long grill.
HTH
Edited by Polo96CL
The 16v/GTi bumpers are one piece, with a large centre grill and 2 smaller ones either side. The 8v ones are 2 peice, an upper plastic peice and a lower valace. The lower section held a single long grill.
HTH
aaah ok.
so what is the standard one then? because there is one with a large centre grill and one small one each side.
The standard is the 2 piece. This one has one larger single grill.
Are you thinking of a smoothed 16v bumper? The top side thinner grills are often smoothed off, unfortuantly this this wasn't an OEM option and has to be done by a bodyshop.
aaaaaaaaahaaaaaaa! i see - so it is smoothed, cheers mate.
so the 8v is the standard bumper then? the same thing?
Yep 8v=standard :)
It's a simple swap to put the 16v ones on, I did it myself and took a couple of hours to get the old ones off and new ones off in then rain :D
cheers mate.
so i guess there are really only two choices when it comes to 6n bumpers unless you wanna go for non vag stuff.
