Annoying noise.
Not sure which area this should be in as i dont know where the hell this rattles coming from. :lol:
It sounds like when you are loosening a tight wheel nut, but it does it over EVERY bump, at first i thought it was the front seats, but i fitted my leathers on saturday and its still doing it. :-(
Really cant pinpoint it at all, it COULD be the back seats, but i cant see how they would come loose to make this kind of noise, anyone else had this problem with the same annoying noise?
Need to sort it out.
Cheers,
Dave. :-D
  • Views 722
if it after a bump could be suspension??
I thought that when it started, it used to do it occasionally, now its over every small bump in the road, it sounds more like its coming from the inside though, i dont have a clue what it will be.
If my coilovers come this week (which i doubt :() i will see if its the same after fitting them :)
