headlight help please
hi, I've got a 6n and i'm seriously struggling at getting the headlights off of it atm.
I've taken the screws off of the top, but i cant get the hadlights off.
what am i missing?
There is a screw (or maybe more) underneath the light to. Its a torx bit. In between the bumper and the headlight.
do you know if there are anymore?
i found one which was visible but the light still wont budge and i cant see anywhere else one could be :s
I can't remember.
I haven't got a 6N, my sister has an I had to replaced the headlight on that at some point last year.
How to remove headlights:
-2 torx screws at top of headlights (completed)
-Take out the indicators using the screw on top of the indicator
-Take out the grille and then the grille surround. bolts underneath indicators hold it in
-you can now see the torx screws underneath the headlights, one either side. headlights shoud now slide out!
bit of a mission but its all easy work. hope that helps!
