POLO MK6 STEERING WHEEL REMOVAL HELP!
Hi there,
I have bought a VW polo 2003 tdi sport 100
the problem is that it came fitted with a sport go-kart type steering wheel (with no airbag) that I dont like so I bought an original polo mk6 steering wheel with an airbag. Now I need to know what tool would I require to remove the large centre bolt on the wheel and where can I buy it from as I have tried even calling vw for the bit but they need a part number? and is there anything I should know about fitting the steering wheel?
Looking forward to your replies
thanks
it was the m12 bit that I was looking for incase anyone else needs to know, does anyone know if the boyracer wheel fitted to my car would have the same vw bolt or would I need to buy a new one?
depends on how the wheel is mounted fella!
Also bear in mind you'll need to get the airbag fault codes reset before your light will go out.
