G40 engine power
Besides the fact of gettin toothbelt's on the charger what else can u replace on the charger for more bhp?? smaller pulley wots the smallest u can get?? ne idea son more power outa the g40
  • Views 756
Porting on the charger is an option, g werks or Jabba sport will help you out there.
Some of the Portuguese guys on here are running considerable smaller pulleys than most of the Uk guys.. sometimes as small as 60.
65mm is one of the best options for the charger, without putting damaging stress on the charger.
Ultimately the scenario is that the smaller pulley you have the shorter your charger rebuilt period is. One thing to note is that if you are running smaller pulleys or toothed belt conversions then a chip to suit will see the best gains out of the engine.
I'd combine a fully ported charger (R1 spec from jabba for example) with 65mm pulley, chip to suit and then purchase other engine parts to help boost the power. Induction kit & heatshield, GT inlet manifold........................
