Towbar fitment - MK3
Right...
Thought id attack this today hoping to get it fitted and have the car off the ramps. I got the bumper off and I'm now stuck lol.
This is the towbar....
Genuine VW
And this is the car...
Anyone Know where anything fits etc?
I've kinda got a idea but the spare tire gets in the way so I'm guessing thats wrong.
Another question.. Is it a 2 man job or is it easy enough to do on my own?
Any help much appreciated
Toby
  • Replies 11
  • Views 2.1k
At a quick look, the bar the actual towbar is joined to bolts to the bodywork under/behind bumper whilst the other two bolts attach somewhere under the car.
Looks alot sturdier than the towbar i removed. That was bolted through the bottom of the boot and through the spare wheel well!!!
I was just about to send you a PM as i remembered you were selling one lol.
I think this 1 goes through the spare wheel well too. After looking at it for about a hour thats the only way i could come up with doing it. but i could be totally wrong.
I've got a rough idea where the bar bit bolts too but its everything from then on I'm not sure about. Don't fancy slicing my boot floor up tbh.
Got any pics of how yours was fitted Jon?
I'm guessing VW would want more than i paid for the car to fit it? lol. Or any garage for that matter.
My tow bar was bolted through the spare wheel well and across the back panel below the boot...got 10 holes in my car now thanks to that. Needed a new rear bumper as well as it had been cut to fit the bar.
Mine was cut too - badly!
I didnt do it before anyone asks! Never even used it!
Edited by vwmk3jon
I'll do you a pic of how mine's mounted tommorrow.
A garage will charge a fair old whack, have a look in your local rag for towbar suppliers, chances are there'll be one who won't charge the earth to put it on. On the other hand, I've done transit ones by myself, yours is bound to be lighter than that.
ITS ON!!! lol
Just kinda drilled some holes and figured it out as i went.
Didn't need to cut anything, no going through the boot floor or anything, Well chuffed lol.
There were little indents in the bodywork where the holes had to be drilled, Drilled them and it lined up perfectly. I was amazed.
So, heres the pics of how things go...
This went in the inside of the boot, Holding up the main bar bit...
This bit is what bolts onto the 2 nuts you can see just under the ball
A bar then bolts from this to the 2 strange things either side of the car
I'll get some better pics up if anyone wants them. Gotta get it up on the proper ramps at college to tighten everything up properly.
Just got the wiring to do now :retard:
that looks a better fit than mine ever was!
yer can we see some better pictures and where did you get it from? i could do with one of these
I'll work on the pictures. It's really difficult to get a decent pic down there. Kinda just go in blind and take pictures at different angles and use the best lol.
Socket and VIN thingy back on..
Bumpers back on...
Bodge hole sealant...
Gotta get some help with the wiring now and I'm all sorted.
How much did that towbar set you back if you dont mind me asking?
Oh yeah forgot to answer that other question too..
I got it for a bargain price of about £25 to my door lol.. That was secondhand off a member on here.
that came with all the stuff i needed, 2 sockets and a bumper
But all the nuts where crushed on the ends, both sockets were screwed and i realized y-day that it was a Bready bumper not a coupe.
New socket, all new nuts and bolts and a tin of hammerite = good as new.
My bumper had the markings for the towbar so i cut them a bit too small yet it was still a bit too big lol, as you can see I've got LOADS of room around the socket etc. Might try and cut some of the plastic up and try sticking it back on some how. Should fill the hole a bit better.
