Which grade of oil do I put in my car?
Shell Lubrication Advisor
Obviously because Shell made it, it says use Shell for everything, however, it does tell you which grade you need to be buying. Other brands are available.
  • 6 months later...
  • Views 4.9k
link doesn;t worky
  • 2 years later...
Shell LubeMatch
Mind you the numbers are bit dubious
Forums posts suggest 75w90 for gearbox, this says 75w80, and I got some raised eyebrows when I said I was putting 5w30 in the engine...
So I'm thinking I'll play safe and go for Tate & Lyle Golden Syrup in everything
Edited by Guest
