mk3 dash in mk2?
Just as title really, would a mk3 gt dash go into a mk2 coupe?
i mean the whole thing not just the clocks (although i wanna transfer them too)
  • Views 1.9k
It is possible but I think you will need to use mk3 door cards as well because of the way they fit up to the dash.
do the mk3 cards fit onto a mk2 door skin then?
mk3 dash will fit but I'm sure you will need to change to a mk3 steering column.mk3 cards do fit with a few mods the internal mirror adjuster needs a mk3 bracket under the door card you also have to make the hole slightly oval in the inside framework.then its just a case of changing clips on the front side of the door to suit mk3 cards.rears cards are a dirrect replacement
luke
cool. might look into that then cos I want the GT steering wheel in my Mk2 :)
You could fit a mk3 GT steering wheel without changing to a mk3 dash mate . :thumbsup:
Iff you have a go at fitting a mk3 dash get athread up on here mate .
I was planning on having a go myself but that will be next year .
Dont want to go all out this year got to many others cars to be working on within the fold ..
Speak to Phoenix, he has recently done this mod and said it wasn't that difficult!
