Pioneer Champion Series 1200W Each Subs x 2 Enclosed, INPhase Box. Sony USB,IPOD AUX etc Headunit. Pioneer Speakers, Tweeters.
hi, got for sale
2 x 12" Pioneer Champion Series Subwoofers - TS-W307D2 - 30 CM 2 Ohm Dual Voice Coil Subwoofer 1200W Max Each.
Key Features:
Composite IMPP Cone Using Interlaced Aramid Fibre With Reinforcement Arcs
Wide Roll, 3-Layer Fibre Woven Radial Surround
Double-Stacked High Power Magnets
Phenol Resin-Coated Glass Cloth Bobbin
Magnet Cover
Single-Sided Push Terminals.
Sony X-Plod GT460US CD, USB, IPOD AUX etc Headunit.
CD/MP3 Playback
Front Usb Slot
S-Mosphet Output Power - 52w X 4
Frontal Aux In
R/Sub Preout
Frontal AUX-IN
This feature allows you to plug into all portable MP3 Players available in the market through the universal 3.5mm mini pin input. With instant connectivity, there will always be smooth connectivity of music from the MP3 Player to the headunit.
MP3
MP3 files can be played effortlessly with the technologically advanced range of headunits. Now you can easily listen to MP3 tunes converted from your CD or from music purchased online.
ATRAC3plus
A high-end digital compression technology capable of reducing music files to 1/20 the size of its original data without any music degradation. ATRAC3plus offers compression bit rates from as low as 48hbps to as high as 256kbps.
Specifications:
Tuner
SSIR-EXA Synthesizer Tuner
FM18/AM12
BTM (Best Tuning Memory)
CD Deck
Drive-S Deck
CD-R/RW Playback
MP3 Playback with ID3Tag v.2.4
WMA Playback with Tag Indication
ATRAC3plus Playback
AAC Playback
CD-Text Display/Scroll
Repeat/Shuffle
Multi Session (MP3/WMA/ATRAC3plus/AAC)
Changer Control
CD Control
Repeat/Shuffle
MP3 CD Changer Connectable
MD Control
Repeat/Shuffle
Sound Control
Amplifier
S-MOSFET Output Power
52W x 4
24 bit DAC
Pre Out
Rear/Sub Switchable
Frontal Aux-In
EQ3 Stage2 (3-Band Equalizer / 7 modes)
Bass/Treble (Low/Mid/High)
General
USB Full Speed
Detachable Front Panel
Pioneer TS-E1395 3 Way E-Motion Series x 2
Features:
Frequency response 40 - 32.000 Hz
Sensitivity (1W/1m) 90 dB
Lowest resonance frequency (FS) 80 Hz
Maximum Power 160 W
Nominal input power 35 W
Woofer size (cm) 13 cm
Woofer material 3D Magnesium Hybrid
Midrange size (mm) 25,0 mm
Midrange material Titanium dome
Tweeter size (mm) 10,0 mm
Power Blades Yes
Top / Bottom mount Yes
Dapic JC 004 Tweeters x 12
Spec:
• Frequency Response : 4.8-20KHz
• Sensitivity : 98dB (1W / 1M)
•Power RMS / MAX : 80 / 120 Watts
•Impedance : 4ohm
•Size : Ø 1.5".
All Items Open To Offers. Thanks.
Edited by Arj
  • Views 553
You put everything except for prices mate :lol:
joker...offers lol no fixed prices.
£50 posted for the stereo?
Thanks, PMd.
offers.
ALL 12 TWEETERS NOW SOLD.
