Wrong Door (6n, 6n2)
So, I'm wondering weather my drivers side door is from a 6n2, reasons being are that it has holes in the side. Apparently the 6n2 has this for the side trim, but the 6n doesn't (look at pic below). also looking the other day i have found that the door is rubbing on the wing, if you imagine being sat in your drivers seat with the door open. look down where the hinge and the wires go through, it rubs on the small pannel behind that (someone said the 6n2 door was slightly bigger) any one had this peoblem or thinks its not a 6n or 6n2 door. or anyone know how much bigger a 6n2 door is, or if it would even fit...
cheers :)
anyone ?
jhmm check the spacve around the door see if it looks like it needs adjusting? as for the holes I've heard of this before and only on the odd occasion maybe it was a idea vw came up with but never carried on with? ajj i can say is adjust eth door if you can abd get it in a bodyshop for them smooted or fit mk5 strips :p
Cheers man, yeah i am getting them all filled n smoothed over just really annoying that it rubs, maybe il go ask a vw garage see what they say, cheers for you are help :)
Was at pease pottage on saturday and I saw a mk4 with holes just like that in the door. Guess there was a run of the mk4's like this.
